Final drive on a 1.8 16V??!
(In Topic #73938)
The gear box on it is a 020 (if i assume this is the orginal box what year would the engine be from), can anyone tell me what final drive this would run in original form and what do people change this for, i have a 205GTi which i sprint and we changed the final drive for a shorter one from a 3.7 to a 4.4 the difference is amazing, i also want the golf to be geared for acceleration not top speed the pug runs out at about 120 which is about right!!!! The car is to be a track / fast road car…
My other question is which manifold to use the one i have is rotten, i guess i need a manifold to fit the 16v engine but also fit the mk1 engine bay, do you then fit a mk1 exhaust to the manifold or need a special one making up???
:dontknow:
Thanx
Aidy
good luck,
paul
supersprint stainless top quality top price.
the other option is to get a 16v scirocco cast manifold ebay usa or gemany then you can buy a downpipe for 16v scirocco.
I ended up fitting 8v gearbox ratios were nearly identical.If you want a lower ratio gearbox i would go for a 1600 gti box.
hope this helps mark
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
Chears
Gurds
http://www.nwlink.com/~vdb/vw/Transmission/speed-ratio.html
VW 020 5-Speed Transaxle Ratio Chart
I have a 9A box as fitted to Campaign Mk1's.
With my reduced tyre size, the theoretical top speed is about 116MPH (Think that was at 6000RPM in 5th - You can use the calculator in the first link to work these things out). In reality, I dont think it would pull that high in fifth gear. I have had my speedo reading 97.4MPH (digital :wink: ) and the car felt like it was flying - probably due to it being so low and stiff!
I have run a 16.5 second quarter mile and passed the line at about 84MPH I think, so there is plenty of scope to get a quick time, if you can get the engine to pull all the way in fifth!
HTH
AL.
My Build Thread
Thanx for your help, i need to get thinking about which way to lower the final drive, guess it will depend on what bits i can source, but it looks like the best way is to find a 1600 Gti gear box then, i have the 16v bits needed so would just need the clutch plate!!!??? Are the companies that sell reconditioned gear boxes etc or is it a search the classifieds / ebay job!!! sorry about the questions but i am new to the VW scene….
I'm new to the scene to… only owned my Mk1 for 8 months and not driven one yet! so keen to though, you'll pretty much find out everything you need to know from the guys here! Very helpful
might be worth putting a post in the wanted section, someone might have a 1600 gearbox they're willing to part with
