Few 20vturbo questions
(In Topic #140781)
I've got a few questions, firstly driveshafts. Everyone keeps saying use 100mm late cabby shafts, then others say 90mm ones have been used? Where is this measurement taken from? Is it the diameter of the joint at the gearbox end? What will a standard 1.1 have? Also there is talk of changing drive flanges on the box? Are these too big? What do they need changing too?
Next up is fuel pump. As my car was originally a 1.1 il need to fit a proper pump. Now I have the pump from my mk4 donor, has anyone ever retrofitted one to a mk1 tank? Just seems logical as it only requires the one pump, is obviously up to job and is easily replaceable
Thanks in advance, I'm sure there'll be more as it progresses
Mat
mk4 pump will never fit its way too big. you need either mk1 gti tank, or late cab/rocco injection or any g40 shape polo lifter pump + under car fuel reservoir with your old tank.
main pump use a std mk1 gti with an M12x1.5 banjo adaptor, then you can use push fit rubber fuel lines, or plastic ones from mk2/3 golf or g40 polo might work.
And thanks for the info about tank, could I not mod the tank and have something like a facet external pump mounted underneath?
if you can find a facet pump with enough capacity for a 20v then fine, but i thought they were more for carby? basically your tank only has outlets in the level sender on the top, and no swirl pot so you will suffer from fuel starvation when cornering plus most pumps wont like having to drag fuel out the top and some will die quickly if they run dry.
hence the need for a late lift pump plus under car fuel reservoir. you'll probably find a std k-jet main pump is cheaper and easier to find than some kind of aftermarket pump, and the k-jet pump is pretty much the best you can get except for a bosch 44 motorsport pump
Fuel pump wise my idea was to get the tank modified so there was a large feed from the bottom to an external inline pump. ive seen a facet red top that claims to be ok for 250bhp, but if the bosch would be better could that be used in the way i suggested?
thanks for taking the time, im still new to these funy german boxes and the garage thats doin it havent done it before
mat
adding a feed to the bottom of the tank would be very difficult to do safely as weld/brase + fuel vapour = bang. far easier to just drop a left pump in the tank and fit a swirl pot. if you could get an outlet on the bottom that would help, but you still wouldnt have a swirl pot so it'll still have fuel starvation on cornering. the reservoir fits easily under there where the accumulator would go if it was k-jet, just make sure you get a bracket to go with it
The shafts I've been offered still have hubs attached, but need one cv boot changing, il have a look in scrappies.
So just to clear it up if I got the complete fuel system from what car would be alright? Ive been looking at gti tanks and pumps but they seem to fetch silly money
if you can get a proper GTI tintop tank then all of the above is not needed, apparently the diesel tanks have the internal swirl pot too. the internal swirl pot will keep the main pump happy and no fuel starvation issues to worry about.
Then fit some kind of main pump that can cope with your projected power, facet, bosch 44, oem mk1 whatever you like. if you get a k-jet type pump you can convert it to push fit rubber fuel lines using m12x1.5 barbed adaptor off ebay, will cost like £3
then its a case of run up some fuel lines either plastic ones of later mk2/3/polo if they fit ok, or run your own rubber fuel injection stuff. try to get braided stuff for a bit more protection. you could use 8mm copper pipe as well for a more oem mk1 feel. the old metal pipes are probably past their best now but if ok you might be able to reuse.
The ideal solution would be a caddy in a scrap yard, then take everything I need from that. It's shed some light on it tho so thanks
Mat
apologies if im wrong….
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
I think its 2003/4minimat said
Mines a year 2000. Il measure later and see
Mat
I have a few questions for you concerning wiring original mk4 1.8t ecu and series 1 & 2 fuse boards but im trying to work it out mysef with the help of your many write ups before I resort to bothering you….
Keep up the good work John alot of us rely on you
http://www.clubgti.co.uk/forum/showthread.php?t=205887
if its on the ceramic fusebox i strongly recommend you replace the wiring for later, though you could add the mk4 fusebox next to it I suppose. not the way I like to do them but its your call
As I said earlier I have 2 or 3 questions so I get back over the weekend if you dont mind…its more of a case of confirming im right
Many thanks John (lagger)
1. what dash is it
2. what rear lights has it got
3. do you want the rear washer/wiper to work
Good idea bad idea…..
