Engine Transplant
(In Topic #93668)
Engine Transplant
Currently have a mk1 cab 89 on a 1.8 8v carb.
It is chucking out blue smoke from exhaust and has failed on high emissions on mot so decided to just swap the engine.
Any advice appreciated. I had read that the mk2 2.0 16v is astraight swap.
Cheers all
Cheapest and easiest is a like-for-like swap, ie replace your existing engine with one exactly the same. Same capacity, type, year. All the items which bolt onto the engine will be on the other one, all pipework connections will line up, and you'll not need to remove things like inlet and exhaust manifold, saving yourself the cost of new gaskets.
Best, is subjective - hence more questions need to be asked:
1. How much money do you have?
2. How much time on your hands?
3. Is it a daily driver, or a 2nd car
4. What's the intended use of the car?
5. What skills do you have or will it be done by a garage?
to answer the questions
1. How much money do you have? - looking to spend around ?500 on the engine itself
2. How much time on your hands? - plenty
3. Is it a daily driver, or a 2nd car - 3rd car so no worries there
4. What's the intended use of the car? - to drive. Girlfriend has always wanted one, so i have restored one, and engine is the next bit.
5. What skills do you have or will it be done by a garage? - None when it comes to mechanics. Friend owns his own tuning company so he will be doing the transplant.
I was led to believe the mk2 engine bolts straight in?
New pump, tank, lines etc
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v312/biggaz/hezzasig.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
mk1 Jetta GTI Spec.
mk1 Jetta GTI Spec.
