engine mount
(In Topic #82406)
engine mount
hi all any one no wear i can get engine mount to put a gti engine in my 1.3 driver thx and wot it involves thx
if you can find a SCIROCCO / mk1 golf caddy diesel or 1.6 petrol as the cars a bit thin on the ground in scrappy without engine chop around the mount i used a bolster chisel take the bit of chassis and mount then drilled out the spot welds in the mount and fit it on your golf chassis there is an indent in the chassis along from the 1.3 mount lower chassis towards the windscreen put the middle of the new mount over the indent and fill in the sopt welds in i seam welded around the mount as weld as i had to do this to my golf for a diesel convert
