DIY hydraulic suspension
(In Topic #151750)
question
Hi, I used to be a Citroen mechanic, Ive not worked on C5s but I have worked on the BX, XM and Xantia, all have hydraulic suspension. Im struggling to imagine how you could successfully fabricate the Citroen suspension to fit and work properly! The oil used is LHM and is pressurised with a belt driven pump, there is usually 6 spheres, one on each strut and 2 accumilator spheres, the Citroens hydropneumatic system is also used with the suspension and steering so trying to seperate the system to just a suspension setup will be quite hard. I have had many terrible experiences with this type of suspension and I dont want to put you off trying it but if I were you I would try a completely custom set up, designed and built by yourself, It will probably be alot easier than trying to make Citroen suspension work! I hope this helps dude, good luck and let me know how you get on. Cheers, Paul.
Goly The Golf, a 1983 5dr 1.3cl having a full resto.
proper Juice setups use modified Tipper pumps, but a normal tipper pump would be the 1st step. then I'd pay rayvern for rams for your car. some things are best not scrimped on.
1982 3 Door - 'BRO' - gone to pastures new
1990 Clipper Cabriolet - Jet green metallic
^^^ what he said (the clue is in our names - www.unitylowrider.co.uk we're both seasoned members of the UK's premier lowrider car club with probably 30yrs hydraulic suspension knowledge between us !
i wouldn't even entertain making my own system as i've seen so many struggle to get not good results, its cheaper and less aggro to buy a system designed for your car, dont believe there is a one kit fits all, thats a sales line to sell you the basics !
Rayvern hydraulics would be my first port of call for a UK system then look to the USA (black magic, Showtime, Reds, Art of Noize) for a US kit but you'll need to get your strutts modified, Rayvern will probably do exchange units.
Go for it mate. Looks like there's some lads here who could help you out.
