Diverter Valve small hose outlet
(In Topic #150250)
Forge 007 diverter valve pipework help!
Hi,
I am installing a forge 007 diverter valve onto my 20vt conversion. Am I right in thinking that the small hose outlet on the top of the valve is for a vacuum?
If so do I connect a pipe from there to the pipe on the right of the intake manifold for the vacuum, along with my servo pipe being connected to the intake manifold?
you should have some vacuum takeoff points on the underneath of the inlet manifold
leave the brake servo vacum on the right hand side of inlet manifold alone . like jonp said there is 3 takeoff on the bottom of the inlet manifold 1 big 2 small. use 1 of the small nipple . if they both are being used use a small t piece and use that as source.
Last edit: by peterg60
Cheers, and then its just a straight pipe from the inlet vacuum to the diverter?
