Converting petrol to diesel
(In Topic #148933)
Ive just bought a 1.6GTD engine from a mk2 and plan on putting it in my mk1.
What are the main issues i'm going to have when fitting?
Glow plug set-up for ignition.
Engine mounts.
Fuel pipes.
Radiator.
Nothing that can't be overcome
Engine mounts.
Fuel pipes.
Radiator.
Exhaust manifold and system???
Cheers guys, like you say the problems only seem to be 'small' when fitting. Hopefully be done and running well by ultimate dubs 2013
Engine mounts.
Fuel pipes.
Radiator.
From “Converting petrol to diesel”
Can you tell me if these are the engine and gearbox mounts i need..
Gearbox..
engine..
thanks
Yer it will need to be chopped moved and flipped.
Will i have any issues with the standard mk2 GTD gearbox when fitting?
Ive got the 5 speed mount as seen above, but will the drive shafts and shifter fit? Im going from 4 speed 1.1 dont forget.
Also is the rear mount the same on all mk1's?
Bloody thing
Bloody thing
Im not sure on the code of the GB. I do have 2 though one from the GTD mk2 and one from a 1.9 AAZ mk3.
