Conversion/engine swap
(In Topic #144892)
i have a mk1 golf cab 1.8 8v and the engine is on its last legs, i also have a smashed up mk1 caddy with a 1.6d engine, im gona have a go at doing a swap the weekend what is involved ??? can you use tank and same fuel lines and how does the wireing work cheers ian
tank should be ok because the main fuel pump for a diesel is on the front of the block..
you'll have it done in a day, nevermind a weekend!
Take it easy ; )
are the fuel lines the same size or dont it make any diffrence, i take it the engines have the same feed for fuel being sucked from the front
Thanks,
James
no reason to not swap the whole engine wiring loom over since you have complete donor, rather than mess about adapting petrol loom to suit a diesel lump.
Take it easy ; )
there is a way to convert a petrol rev counter to diesel, but i will have to get back to you next week as the link is on my work pc. it involves resoldering some circuits on the rev counter pcb mind you
