Changing engine mounts from 1.3 to 16V... Please help???
(In Topic #80443)
You need to carefully remove the driverside mount by drilling out the welds. Take this mount and turn it upside down, move it backwards about 8 inches and you will see a groove in the chassis rail. there are two cut out notches on the mount which need to line up with this groove. Weld it back on (More weld is good - Run some along the sides etc…), job done!
My Build Thread
