Camber setting
(In Topic #89533)
Camber setting
Hi guys not sure were to put this so put it in "Mods" the problem what we have does anyone know "North Yorkshire ish" that sets the camber on my sons mk1 Golf 1.3 Driver or is it summat we can do our sel ?,,it does"nt pull to the left or right but it corners different "left To Right" i was thinking that the camber adjustment could just do with checking anyway,,its had jamax lowering springs fitted at some point so my guess is its just been bolted back together & needs adjusting,,any advice would be great thanks guys/gals regards Rick,,,we live near skipton :dontknow:
If you can get over to Harrogate, I'll do it for you. Mine is set to zero toe, 1.5 degrees negative camber and works a treat. It does have polybushes in the front arms though.
