cabby - manual to electric roof.
(In Topic #81305)
http://cgi.ebay.co.uk/…Z9889QQrdZ1QQcmdZViewItem
what will i need to do to fit it to an '81.. Ive looked in the back of the car, and there are threaded mounting on the shell, and a rod to accept a tailgate style ended strut on the hood frame. Do the hydrolic rams bolt on the same mounting points with the same method? thanks if anyone can shed any light on this subject.
Http://www.ihidden.com
cabby manual to auto
Use the search facility to find the post, that contains photos etc.
Don't forget there is wiring, switches and relays to fit also.
chortle said
This has been covered before.
ive already bought a pump, set of rams and wiring harness including switch thinking it would just be a simple switch over replacement like my mk 5 escort cabby was until i seen a few posts on here saying the frame does need brackets welded on, I cant seem to find the post you are referring to in the search if anyone could put a link to it on here it wouldbe very much appreciated, the wife struggles to close the manual roof so hopefully I can manage to do this conversion
If it's that stiff I would oil all the pivot points, so it's nice and free.
I will have a look for you when I'm on the laptop.
Just using my phone at the moment.
Apparently there is a guide in one if the Haynes resto manuals.
Unless someone feels like taking some pics and measurements for you.
