Brakes Upgrade
Front Brake Modification |
VW 280mm Mark3 GTI Setup | [1 vote] |
Vauxhall Vectra Setup | [4 votes] |
This poll is closed. You cannot vote unless it is reopened. | |
(In Topic #114316)
Brakes Upgrade
should help you out with the exact parts required. Vauxhall is better because of larger pad area and its cheaper.
You can use the 280mm G60 discs and accept the small overlap the pad will have over the edge of the disc. Also there are some other cars with similar/same PCD as the VW, who's discs could be used - for example Fiat, Rover, so you might be able to find a 285mm or 288mm disc out there. I've never looked into it and I'm happy to use G60 discs.
I have the mk3 set up on mine and it works a treat, plus its nice and cheap, ?50 for adaptors, ?50 for calipers and carriers if you shop around, and then all you need is the mk2 16v servo and master cylinder as the larger piston needs more fluid so with the sock mc your pedal will be loooooooooong, but this will be the same for both.
M7R said
how much bigger is the pad area? and how much is un-used?
The thread on fastgolf has the info:
paul_c said
May be of some use?
and I think the piston on the teeves are 57mm vs the 54 on the earlier golfs, but you will also notice that the piston over hangs the pad area, and also dont assume they are better than the golf set up, as a few folk will vouch for how well mine stops.
