Brakes again, 4 outlet Master cylinder
(In Topic #135004)
I've upgraded the servo and MC to MK2 16v items from my original setup because of the ABF conversion. Originally the lines were as below, i have a brake switch on the pedal so there are no in line switches to worry about
I have now got a Mk2 master cylinder as pictured below. How do i connect the lines to this one? I've read about connecting them so that the diagonal corners are on a t-piece so if one outlet fails you still have some brakes.
How do i connect mine with 4 lines and 4 outlets? Both fronts on the left as you look at the engine from the front and the rears on the right?
Circuit 1:
Front left Master Cylinder outlet = Front O/S wheel
Front right Master Cylinder outlet = Rear N/S wheel
Circuit 2:
Rear left Master Cylinder outlet = Front N/S wheel
Rear right Master Cylinder outlet = Rear O/S wheel
Hope that was what you were asking :mrgreen: :mrgreen:
GAMMYGOLFGTI said
Connect systems up diagonally, so looking at your master cylinder from the front of the car it would be something like this……………
Circuit 1:
Circuit 2:
Yeah that's what i meant, so as below then? I wasn't sure how the insides of the cylinder were plumbed :redfaced:
Yep that's the way, the opposing ports on the master cylinder are the same circuit :wink:
So I have a 4port 16v MC, two hyrdalic nline brake switches i dont want to wire. Can I use the above config with 2 x T pieces to the brake sensors?
or should i plug the brake sensors directly in to the MC ports and have 2 ports spilt going to the brakes?
Thanks guys!
Briano1234 said
I have seen many a folk use "t's" to plumb on the switches, and I have seen others move the brake light switch to the pedals using a Cabriolet switch so they only had to plumb one of them.
Any decent write up/pics on the bits needed and how to achieve pls sir ? if its just pedal then wiring only and no pipework right?
