Brake Conversion
(In Topic #82479)
Brake Conversion
Need Advise
Im just about to do the same on mine but im unsure about the servo and master cylinder thing??
It says it is 'best' done with the 22mm master cylinder?? and the servo up grade, where are these parts from (16v im guessing).
Also can it be done with out up grading the mc and servo and leaving the old one on.??
Any advise would help greatly.
Thanks.
Check the braking faq for how to do it and what cars to get the parts from… I would get a new m/c from somewhere like gsf (?25 ish…). I got the 22.2mm from a passat as it has 4 outlets rather than the 2 the 16v golf one has…
brake conversion
Re: brake conversion
dubkev said
You have to shorten the M/S link to fit, exactly how much etc im not sure yet as im not quite at this stage.
10mm. I think there's a pic somewhere in the Braking FAQ, which shows the simple mod. (I took the pic).
