Box's to fit the kr engine
(In Topic #144464)
the main headache with cable shift box is getting the clutch working, either you have to mod the bulkhead and pedal to accept a hydro clutch master cylinder, or find a SEAT abf/TDI cable conversion kit
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
rubjonny said
you could fit the cable box if you wanted, and tbh it would be the same amount of effort as converting your car to rod shift since its an automatic currently. does the steering rack have the manual brackets on? if not thats another thing you would have to change if going rod shift, but not if you go cable shift.
Well i have everything i need for rod , steering rack , rod selector , gearbox , shafts .
I just wanted to know how easy it it to just keep my cable kr box on and change the selector , because i cant see how i could fit the corrado selector into mine would i need to redrill any holes in the car to bolt the cable selector down . ?
