Best rad, intercooler and oil cooler setup for 16vG60?
(In Topic #146284)
Hi all,
Just wondering what those of you with 16vG60 conversions are running? How do you fit it all in with an oil cooler too?
Any help with or without pics much appreciated!
Cheers,
Cheers,
not got a g60 but i have the mk1 oil cooler on my kr engine just bolts on the block using the mk1 oil filter housing if you swap the pipe that the filter screws on for the one from the 16v filter housing you can use the 16v cooler thing.
it only has one pressure switch on and a temp sender on the front
im guesing might be a bit tricky with charger in the way but they can mount anywhere as long as the pipes are long enough.
