Best fuel pump solution for 1.8t 20valve conversion
Well as title the engine is now in my mk1 and I need to think about a fuel pump solution (my car was originally a 1.1 carb model).
What is the best option, I've got a mk4 fuel pump but its too big to fit anywhere 8O I know people use gti tanks and pumps, are these ok up to circa 250bhp?
Just need a bit of guidance really
Mat
I used the bosch 044 and removed the acululator and replaced it with a high flow filter.
the 044 in all honesty was overkill the original 1.8 8v pump was man enough although mine's little inlet filter was full of swarf when i removed it.
hope this helps.
VW t4 - tdi conversion
VW golf series 1- 20vt conversion
Peugeot 205 gti track car
so lift pump in a gti tank, a big fuel filter then a bosch 044?
mat
Sorry to hijack the thread but am i thinking that i will need to change my tank from the 1.3l orig to a gti 1.8????
A standard GTI set up is more than enough, with or without the accumulator. The k-jet fuel pump can cope with a lot. Just make sure the standard fuel filter is correct for the engine type your putting in.
Cheers,
Adam.
'83 MK1 Golf GTI
'08 Audi S3 2.0 16v TFSI
as above gti pump is good for loads of power.
with that you have 2 choices, either fit a late cabby, rocco or g40 shape polo lift pump and plastic fuel reservoir with your old carby tank, or fit a proper mk1 gti fuel tank with in built swirl pot (some cheap pattern tanks dont have them!)
you dont need the accumulator so bin that, fit a barbed m12x1.5 banjo adaptor and then you can use push fit rubber fuel lines or later vw plastic lines
Well I've got a gti lift pump so that should go straight in my carb tank?? Then gona use a big fuel filter and one of the Bosch 044 jobbies.
Don't suppose you remember what filter you used do you?
Mat
if its a mk1 cab or scirocco lifter then it'll drop right in yeah, mk2 one wont. any efi type inline filter will do, i.e. mk2 digifant gti or mk3. mk3 comes with a handy filter carrier which might be useful too you
Thanks for the info, yeah it's a mk1 gti pump so thats that sorted atleast.
Mat
