BBS RS
(In Topic #78055)
BBS RS
what does the 070 bit mean? also can i put 195/45/15s on ?
RS001's are the money fetchers I think!
195/45/15's will fit.
As for arch clearance… :dontknow:
Just ensure that they are 4 stud (PCD 4x100) and that the offset is between about ET25 and ET38. If the number is any lower, you're going to have serious arch clearance issues and if it is higher, then you may find the tire rubbing on your struts (Can be cured with spacers…).
My Build Thread
thanks alot
Andrew
What are the critical dimensions on yours Andrew?
My Build Thread
got some on the cab at the minute but only 6.5 wide with colour coded centres. To refurb these and get deeper rims and new bolts will cost the same as buying some already done! go figure :?
so thought i'd buy some and then sell mine?
Andrew
P.S. i have just got my 9-spokes refurbished and they look top notch. Lovely set of winter wheels!
