Audi throttle body high idle .
(In Topic #76856)
Racing is life . Anything before or after is just waiting - Steve McQueen
Re: Audi throttle body high idle .
geezer said
would fitting the idle screw from the original throttle body help ? .![]()
that should do the trick
I have a audi throttle body too and will be fitting on my 2.0 8v conversion.
Did you match the body to the inlet manifold? :dontknow:
i cut up a piece of metal and used that to adjust the idle but i think mrv put the idle screw in from the standard throttle body…
