audi 80 coupe 2.6 v6 Calipers and Carriers!!
(In Topic #108950)
he who dares rodders
gundel said
i dont know about an audi but the mk2 golf 16v discs are 256 so they might fit and the golf is a strait swop its when you bigger thats when you start to need adaptors
The discs are but the calipers aren't……you need to use either Vauxhall components, or Audi calipers/carriers. I think the "Audi 80 coupe 2.6 V6" (can you confirm the model, that's not a model of Audi!), well the engine size you've quoted, is a later model from the ones that do fit (you're looking for the calipers and carriers). For info, the calipers are the same on later Mk2 Golf GTI 16V and the correct Audi.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130293591293&ssPageName=ADME:X:RTQ:GB:1123
paul thats the link with the car info, he says he wants ?140 posted for the whole front brake setup seems a bit pricey to me.
I just need to know if they will fit!!
On Ed38 im picking up a mk2servo and mc from 16v, hes got the disks calipers and carriers aswell. But if they wont fit there is no point… :dontknow:
The correct caliper and carriers need to convert your Mk1 to 256mm brakes can be found on :
Audi 80 quattro (83 to 85)
Audi 90 5-cylinder (85 to 87)
Audi Coupe 5-cylinder (85 to 88
Scirocco 16V (if you can find one !!)
Note:- Pads and Discs from the same vehicles will also be needed. >88 Mk2 16v discs and pads are also compatible with the conversion despite the calipers and carriers not being so.
The specific part numbers for this caliper carriers (if bought new from VAG are):-
Part Numbers:-
Caliper carriers - 853 615 125 (x2)
Carrier bolts - N900 689 02 (x4)
Sliding pin bolts - 321 615 141 (x4)
chudd said
Mk1 -> 256mm Brakes
I'm sure the 256mm front calipers from a mk2 golf 16v were fine for this conversion - and the only troublesome part to source were the carriers (which can be found on those Audis)?
sciroccoregisterforum.co.uk • Index page
Website Manager
gundel said
wouldent be easyer and cheaper just to put mk2 16v 256 dics and calipers :dontknow: as thats what iv done on my mk1
The 16V calipers can't bolt onto the Mk1 hub carriers (the bolt holes are different distance apart)…..not without the Audi caliper carriers discussed above. How did you do it without using these?
gundel said
inderstand what your saying paul but i got mine from a show and he said that they was off a mk2 and that they would fit and they do so does this mean they are scirocco :dontknow:![]()
Black bit is the carrier :wink:
