anyone know the wiring diagram to wire up a agu lump into a
(In Topic #144361)
hi there all i am doing a 20v agu lump conversion in my mk1 and need to know how to wire it up does anyone know what wires i need wire up exact, looking for a diagram, im wiring it into a 1990 golf mk1 cabriolet, and the agu lump is from a mk4 golf
check this thread:
http://www.clubgti.com/showthread.php?205887
check out page 5 i made a full list of what pins to use for CE1 -> MK4 conversion loom. AGU is pretty much same as AUM/AUQ, but simpler as no dbw to worry about. the only thign to watch out for is the early AGU with 10 pin plug on the 2nd loom is slightly different to the later one check the brown plug thats how you can tell for sure. late AGU and AUM/AUQ pin 2 is the ecu earth trigger, on early AGU one of the reverse switch wires goes there.
find out which loom you have then pick the right diagram from my sig
