amp wire
(In Topic #78222)
amp wire
were can i feed a amp wire in to the car from the engine bay. :dontknow:
Through one of the numerous wiring loom grometts in the bulkhead maybe… :dontknow:
My Build Thread
Looking at the engine bay, there are a couple of spare grommets under and aroudn teh servo area. you'll need to pull the carpet and sound deadening down insiude the front footwell to get to it once its thru though. That's the easiest place to feed it thru from. :wink:
errr yeah what they said^^^
just don't do what I did and make a cut in one of the grommets to fit a wire through is I've just found out (after some detective work) that this was the cause of my wet footwells! I'd cause my own leak as the water ran down the wires and dripped down ops:
black 5 door mk1 GTD
mk1 scirocco Gli in bits
once you've fed the wire through and it's in the right place use some silicone to seal it so it's watertight
www.msportcam.co.uk
thanks
thanks everyone ill shall try today :mrgreen:
