agg into mk1 wiring help needed please.
(In Topic #146695)
what ecu did you use? if it was a 2e you have to change the dizzy for a 2e one
see my sig, g32eecu.pdf thats complete 2e ecu wiring diagram for ya
I forgot to mention that the fuel rail is different too! looks like it still got the agg/agy fuel rail which is sequential injection setup, 2e uses batch fire injection.
i take it you left the wiring loom on the engine as is, and just popped the 2e loom round plug on? because that wont work the engine loom is totally different. you need to get the engine section from a 2e, and fit a 2e inlet manifold, fuel rail and injector setup
you might possibly be able to keep the agg/agy fuel injector setup though, to convert sequential loom to batch fire you just need to splice all the injector earths to 1 pin if that makes sence? you'll need the 2e engien section of the loom anyway which will already be setup like that. i dont know if the 2e plugs will fit the agg/ady injectors mind
