aftermarket electronic speedo conersion
(In Topic #129559)
hi all, does anyone know of an aftermarket electronic speedo that will run in a mk1 gearbox in the same hole an be driven by the diff but can be wired up either into original dash gauges or aftermarket gauges.i would like to do away with the cable an put my own clocks in but dont know if theres anything available without fittin wheel speed sensors an a pick up ring or something of that sort?
cheers, boyle
cheers, boyle
mk1 golf - resto
mk3 polo breadie - daily banger
yes mk3 speedo sensor will drop into your box, just need to get one to match your gearbox. what car is it
ah i knew mr rubjonny wd av the awnser.im usin a 1.8 8v 5 speed box.dnt know exactly what code it is.do you know if the mk3 sensor can be wired up to be used on different speedo clock?im gessing they wd need to be callibrated an such!
cheers,
cheers,
mk1 golf - resto
1.8-2.0 8v mk3 sensor will fit right in
no idea if the aftermarket speedos will work with it, best to talk to the manufacturer?
sweet! that means i can get rid of the speedo cable hole hahaha. will look into runnin aftermarket clocks. thanks for your help mate
mk1 golf - resto
Hi all. Would a mk3 speedo be needed to be used and fitted into mk1 clocks? Thanks
you would need some kind of mechanical -> electric conversion or strip 2 sets of clocks down to see if the mk3 speedo part eill fit. its been done but not easy
Thanks rubjonny, much appreciated, I will get a mk3 speedo and see how I get on.
