AEB oil and coolant lines
(In Topic #147192)
Any help would be great!?
1.3 Driver - 1.8t in progress
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=56551
Daily driver : e36 325 tdi se / slammed on konis and bbs rco401's
Daily offroader : discovery 1 6" lift monster
The main prob i'm seeing so far(well first hurdle!) is where to fill it up from the expansion?? was planing a T at the bottom rad hose but looking into bits cant seem to fit anything in the space awell as going to pump.. What diamiter is that outlet from the bottom of expansion?? I don't have one to measure…
I also just found this picture…
Which sugest's the T/Y isnt at the bottom rad outlet to pump.. Where else can you fill to??
I've also just noticed on some diagrams that some set ups have water cooling for the gear box oil.. Do you have to worry about this on VAG gearboxes??
\/\/ The beast to be…!!!
(loads of pics) \/\/
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=95838&highlight=
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
SSC ELECTRICAL
Got a bora sport to donate ita engine for ring mobile was stripping the turbo out and my juice had actualy frozen between mouthfulls so tools down till i get space inside or it warms up
Never had any experience with water cooled boxes but ill check the tank size
Driveing lmao brb
Hello
I have my engine out a b5 A4, and to make it fit on mk1, i have swap the next part's : oil sump si turbo return line's, oil coller , crank/alternator an water polley out of mk3 1.9 TDI, they are bolt on's with no prblm.
Basicly the engine block is pretty much the same.
You getting a project build up of yours? be good to see a few pics
SSC ELECTRICAL
SSC ELECTRICAL
untill then just reading
this is the car when i was running 16v, before going for the amateur hill climb competition
Uploaded with ImageShack.us
sorry for the offtopic and my poor writing skills
I was looking into mk3 tdi coolant pipes and turbo lines on VAG-CAT.. I think there will still be alot of adapting to do??
When I offered my K04 turbo up but the support braket is way off on the AEB, what block is it on the B5?
Welcome to forum by the way!
SSC ELECTRICAL
SSC ELECTRICAL
well is the same . i have the '97 AEB 150/ k03 turbo lump, i have fitted the AGU intake & exhaust manifold, plus the water pump & oil cooler housing plus turbo line's from mk3 tdi engine that i found at a local bracker near bucharest. the rad is from mk2 gti, the alternator + bracket i use'd the ABF one's with the crank polley for v belt str8 allignment.
unfortunately i on hollyday i dont have acces to my work pc, there i have pics and details.
this is the only pictures i have for my notebook screen save.
on 3'rd of jan i will start warking i will post more pics then
The cars in the background look interesting..
SSC ELECTRICAL
SSC ELECTRICAL
10x, thecar is built in our garage, is built after the super 2000 model, is the only fabia like this from romania, the engine is AEB N/A built in cehoslovacia at Motordesign by giri smath, it's on ITB, motec stand alone, 6 speed secvential gearbox Skode Motorsport, it' has around 220 at the weels, here is a video with the car from the 2011 spring run at rasnov near Brasov,ShaunyC said
Sounds like you know what youre on with!Fair play..
From “AEB oil and coolant lines”
http://www.youtube.com/watch?v=VwVocOguUuc
the evo has around 300 is rally built it pulls around 300 horses with the group N restriction on the intake of the turbo.
