Accumulator question?
(In Topic #160947)
Hi all, I'm doing a 20V T conversion and I just wondered if the accumulator is still needed? Only reason I ask is because I removed the bracket for it and don't know whether to weld it back on before I epoxy mastic the floor?
Cheers, Andy.
Cheers, Andy.
Website Manager
Thanks for that Ade, much appreciated. I might do the same for the fuel filter
Hi Andy, accumulator only needed on non EFi cars in order to keep fuel pressure up in rail after switch off (to stop the car churning over on start). What you might need is a swirl pot if you start to have fuelling issues but the guys already running turbo's should be able to advise.
Cheers for the info bud, glad it's not needed as I forgot to weld the bracket back on
