ABF 2.0l 16v conversion help/mk1
(In Topic #82204)
I too am in need of a new manifold for my abf conversion. Ashley don't do one, tsr are being obstinate again, I have messaged long-life, super sprint and storm and await their responses. The issue I'm having is that I still have the mk1/2 box with the rod change and may retain this. Albeit my current vw tech did state it won't last the course because of the power hike. I digress, are there any further alternatives to the above or can anyone make a specific recommendation or link to other providers of such goods? Many thanks guys
I'm changing the rubber fuel lines and putting a reflective heat guard over the steering gaitors too.
I'll try and find a picture.
Here you go!
Last edit: by mark1gls
foir anyone else lookin g to use the stock 16v cast manifold and an 020 box you'll have to make up something like this:
even with the big kink I had to chop a notch out of the relay shaft to clear. even VW did this on the scirocco 16v, I did try to order a rocco relay shaft but they went NLA after I talked to VW about it
