8v turbo
(In Topic #99439)
8v turbo
some will probably think for best power etc it seems abit pointless goin for an 8vT as 16v has more power na than the 8v and then a turbo wud make the gains alot more significant. however if i wanted a car that had lots of power to blast round the countryside i'd buy a tin top and then do it. truthfully, i jus wanna dump valve again
g40'd ratter
<div><embed type="application/x-shockwave-flash" wmode="transparent" src="http://w139.photobucket.com/pbwidget.swf?pbwurl=http://w139.photobucket.com/albums/q312/Forgeman/75e604af.pbw" height="120"
1. lower compression: forged pistons, decompresion plate or 2 head gaskets :dontknow:
2. new manifold
3.custom managment i.e. mega squirt
also you would need to know that your engine is in tip top condition.
the chargers aren't that bad service 40000 miles with a 68mm pulley
g40'd ratter
but if you wnet the efi route it would be loads better if it was me id get a 2l bottom end and then stack a coulpe of metal headgaskets then run about 8 psi with a t3 tubo job done
you can run off the mk1 k-jet system, using an audi turbo wur and dizzy vacuum canister. crude, but it'll work o.k. i wouldn't want to run big boost on it though.maccagti said
could you not run it off the k-jet then? my r5 didnt have a ecu, that was a carb engine tho, with manual choke, but cant imagine it bein that difficult surely?
83 BBS MK1 GTI 69 T2 PANEL VAN i am back let the trouble begin
ive a 16v block (1.8kr)
s2 pistons rods
1 turbo technics kit
i want to aim for 220 bhp ish can i get this on k-jet or will i need extra injectors?
as any body used a volvo metering head or a 5 pot audi head as that would give me a 5th injector to help with the boost
thanks
bbsmk1 said
turbo technics conversion :wink:
was just gonna say! turbo technics do a manifold and pretty much a whole conversion if you can find one!
standard loom ect just a remap on the ecu!
mk1 golf gti in porsche ocen blue and polished porsche 7slots
i know all tt kits were good for 150ish standard but with a new turbo and more boost what type of level can i take the k-jet to?
where would i find out the pressure settings of the k-jet and what type of pressure a good system could be pushed to so i can figure out my boost limit
thanks
get the following done
lightened crank
custom rods
custom pistons
total seal rings
spacer plate for head
oversized valves
then get a custom manifold made get a T3 turbo flange welded to it
then its a case of getting enough fuel to the engine now you will be wanting to see 12 to 13 afr on boost or it will be rebuild time again
the fuel side of things is where it will get messy :mrgreen:
Never had any major probs with mine (only when i give it to so called experts does it ever go wrong !!).
Details of the TT conversion can be find on my website here:
http://www.vwturbo.co.uk/index_files/Page1060.htm
hope this helps.
Bit of info, my car has always run K-Jet wiht the Turbo Technics, runs std pistons machined, 1 bar of boost on high setting and has ran like this for 90,000+ miles. Before this it was running .65bar high boost setting and ran for 100,000 miles before a so called specialist garage set it up and it went pop !! So in all a total of 196,000+ miles on k-jet with the Turbo. Cant complain at that I reckon for reliability :wink:
