4X4 VR6 TURBO
(In Topic #98759)
4X4 VR6 TURBO
Then there's a lot of fabrication work, eg creating new mounting points for the rear suspension, moving the fuel tank and maybe spare wheel well too, no doubt you'd need another custom exhaust system built to fit round the new stuff at the back. Its all possible, but you'd ideally want access to a jig and 4 poster to do a lot of the work. Maybe 300-400 hours work?
If you're running a turbo VR6 then I'm estimating your power is around the 300bhp mark, plenty of people (in the USA) are successfully running this still with front wheel drive. So, maybe you need to concentrate your efforts on getting more hook?
FWD is VERY capable of putting the power down if you get it set up right. I run a 400+ BHP Fiat Coupe turbo and i have no traction problems after 1st gear in the dry, and even in the wet, I have to provoke the car to get wheelspin in 2nd
To give you an idea of what its capable of (bearing in mind its a 1300kg car) I posted a 12.38 at Santa Pod last weekend. About the same as a Lambo Diablo, Cerbera 4.5 or a Ferrari 360.
My honest answer would be to stick with FWD and get it set up right - the inherent low weight of the shell will make for a staggeringly quick road car.
Having said all that, if you're chasing a fast drag time, RWD is the only answer - my car would post an 11.something if it was driving the correct wheels. There a re a couple of 4WD Fiat Coupe conversions, one of which is pulling 10 second quarters - this would suggest a VR6 turbo would be in the same bracket (when I was at the Pod last weekend, there was a staggeringly rapid white Golf, running about 500+ bhp through a 4WD conversion - but he reckons there was about ?40k of work and parts in the car)
don`t put off by prices if you do it yourself, youve done the hard bit, the rear section is easy, just lots of cutting and welding, no driveshafts need to be cut or subframes just the prop shaft, wheel well needs to be removed but i would put in a larger tunnel, plenty of room left for petrol either side of the prop or behind the rear diff or even in the boot
g60 steel wheels 15" 195 45 15 and there is 40 psi of pressure in the front 2 tyrespaul_c said
What wheel and tyre size do you have? And make/model of tyres?
toyo proxespaul_c said
Make and model of tyres?????
