2e engine conversion
(In Topic #76445)
![Jon-Boy in the usergroup ‘Local’ Jon-Boy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
ive bitten the bullet and gone a got my self a 2l, 2e bottom end, which im gunna couple up with a rebuilt and modified DX 1.8 gti head, which will also have a newman, road rally cam 280deg duration.
anyhoooo, what exactly will i need to alter in the swap, i know ive got to retain and use my gtis oil pump and bottom pulley.
what else do i need to do?
im in the dark when it come to what needs altering on the dizzy aswell.
which head gasket should i use?
plus theres a blanking plate i need from (perhaps) tsr but at ?150+ seems rediculously expensive!
oh yeh, which cam belt should i use, being a taller block n all that!
any ideas or thoughts then that would be sweet
I know there are other threads on this but cant seem to find the relevant info.
cheers 8)
1983 mk1 gti 2.0l 2e powered
newman cam
ported, polished, big valve 1.8 head
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
![Avatar](https://i3.photobucket.com/albums/y62/kins888/l_11169df0ad11820901b08b35d181a2fb.gif)
![kins in the usergroup ‘Old timer’ kins in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
kins conversion
For the tall block there are issues with exhaust manifold catching on the bulkhead or steering rack (if your'e running a 4-branch/tubular type). You need a exhaust manifold spacer. (available from TSR)
The oil filter housing has different bolt holes so you need the correct housing.
The breather hole at the front of the block can be blocked of with a blanking plate. If you're planning on using and audi 5 cylinder WUR you can make a bracket to bolt it to the block and block the breather :wink:
You need a spacer ring to fit your distributor (again avilable from TSR) The final drive cog needs swapping for the 2.0 one too.
The golf sump needs to be fitted.
You can use 1800 or 2000 head bolts. They are stretch bolts so need to be new.
Fit a multi-layer, metal, head gasket from a 2 litre as they are more reliable than the composite type.
I thinks thats about everything…….
Hope this helps and if you need any help get in touch.
Cheers Karl
right, not wanting to be the forum dunce, but what exactly is a 5 cylinder audi WUR???? :?
im going to be using the standard manifolds etc, do you think there will be any fouling as i am unsure whether you mean that you get fouling if you use a 4 brancher or not?
ive requested a broucher from tsr, is everything in there?
has anyone here done the 2e swap? if so anything i should know before i dive in!!!
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
AUDI WUR
I'm not sure if the standard cast manifold will catch on the bulk head :dontknow: . I doubt it would impinge on the rack. It's just that most people who do the conversion add a performance manifold as it gives a big gain that's why I mentioned it as a problem for a tall black.
thanks for the speedy reply.
dont think i can afford the extra expense of a performance manifold???
if anyone has a piccy of a fitted WUR from a 5 cylinder audi then that would be cool so i could visulise it.
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
![Shortstuff in the usergroup ‘Local’ Shortstuff in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![:o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/shocked.png)
MK1 GTI Campaign
MK2 GTI 8v
Imitation Magic Tree - 'Black Ice' smell
Plenty of rust
Embarrasing fuel problem
Porous cooling system!
MK2 GTI 8v
Plenty of rust
but i will have an original 1.8 gti engine for sale. with a spritely 177 thousand miles on it!
so just run in really!
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
![geezer in the usergroup ‘Local’ geezer in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Racing is life . Anything before or after is just waiting - Steve McQueen
im sure your knowledge will come in handy when im mid swap!
im having troubles finding the kit from tsr though, all i can see is the 3a kit which is ?165!!!!!!!
where did you get the 45 quid one from?
plus i notice your based in south wales, you should come along to the south west meet in feb, be good to have a look at the finished product!
Jon
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
you know it makes sense!
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
Wales is a tough one and the west has to fight for its members. Come and join us geezer you know it makes sense!
NWM rule ok!
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fwww.bees-online.co.uk%2Fpics%2FyelljacketBL.jpg)
never knew it was because i was from devon???????
shebaite
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
Jon-Boy said
cheers for the essay geezer! top notch!
Jon
When and where ?
Got the kit from tsr i'll have a look in my reciepts box.
No worries on anything you need.
Jon
When and where ?
the meet is on sunday 12th of feb, anywhere from midday.
check out the the post in regional meets, SWM7.
its in taunton, we have a chap coming down from hereford so very multi regional!!! plus we have a load of chaps come from bristol so you will probably see them on the way down!!!
if you look on the tsr website, then the blanking plate is under the bore and build categorey.
Jon
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
Jon that kit from tsr was ?60 inc vat and is listed on my reciept as-
1.8-2.0 distributer ring ez/2.0con1
1.8-2.0 breather bung round ez/2.0con2
1.8-2.0 breather plate ez/2.0con3
Those are the tsr part numbers
hope that helps
I was going to have a local machine shop make up some copies for me because i though that ?60 was a bit on the steep side but i run out of time .
Kins i will check the posts for the northwest meet too.
can i ask how long ago you bought the kit?
just so that i dont sound like a complete nerd when i ask for it for 60 squid!!!!!
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
ive requested a broucher from tsr, so hopefully it will all become clear!
cheers for your advice so far mate.
Jon
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
newman cam
audi throttle body
SWWWWEEEEEETTTTTTTT
