20vt wont start with mega squirt
(In Topic #136557)
also make sure your trigger angle is setup correct or have it fixed at say 10deg just to get it started and no more. tooth #1 angle btdc i think is 84.
have you got the required fuel value setup?
squirts per engine cycle = 2
also fuel pump cable from the ms goes to a relay where you splice that into the fp wire in the fusebox. the ms earths earths the relay so you would need +12v for the fuel pump and 12+ to the relay for the ms to earth it, if that makes sence!
something similar to this diagram but its for an igition coil and not wasted spark
hope that helps!
james.
'83 mk1 Golf GTI Lhasa Green
1.8T 20v conversion –> http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&p=332518#332518
you dont need the ignition amp also why have you got 4 ignitors if your running wasted spark? you only need 2
pair up the coilpacks 1&4 to ignitor 1 then 2&3 to ignitor 2 simples brrom broom
