20vt Speedo and Rev gauge
(In Topic #152185)
Hi,,, What do I need to connect my 20vt engine to my mk1 clocks for the rev gauge and speedo?
speedo is simple, fit mk1 1.0-1.3 speedo cable (matched to age of car) then unscrew the 3 pin plug off the back of the mk4 speedo sender, 1.3 cable fits right on there.
for rev counter you need oen of these assuming its oem management:
http://www.edition38.com/forums/index.php?showtopic=440379
Link doesn't work Jonny mate
Cheers John, it's a megasquirt ECU I'm using.
Thats the first time buying a 1.3 driver has came in useful for this conversion!!
works fine for me, maybe you need to log in? Anyway its the MSD PN 8920 you want for oem ecu, ebay has a couple usually.
for megasquirt if you're going wasted spark you want to do this:
http://www.clubgti.com/showthread.php?214566
Apologies I logged in and it worked. Cheers
speedo you need
http://www.ebay.co.uk/itm/290750410855?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
as rubjonny posted make sure the didoes are the correct way lol
you can get both dideo of ebay or send me pm i have the correct 1s here you can have
hmm my msd isn't working as yet
