20vt problems
(In Topic #159365)
Finally got my 20vt running with megasquirt ecu but noticed a few problems, first is my 16v tensioner although dead tight wobbles left to right quite a lot is this normal? And my vr sensor seems to be getting quite a bit of interference causing the rpm to not read intermittently on ecu any way of cleaning up the signal? Other than that it sounds awesome
Used washers pretty thick about 8mm, was thinking it could be that , vr cable is shielded but gonna seperate it from loom, I'm running ms2
That's the thing, the cam part is tight and belt runs straight but the actual pressed steel wheel seems to run out of line. Gonna take it off tomorrow and swap washers for a milled piece I had made and see if I can seperate the vr sensor wires, do they need a resistor in line?
