20vt Coolant Plumbing
(In Topic #162833)
Theres a picture of the coolant plumbing that I have set up on my AEB engine. Can anybody check this and give any comments?
Tbf it hasnt had any problems with the engine temp at all, and the heater itself seems nackered because it also doesnt turn off all the time when set to 0.
I have labelled the coolant temp the thermostat for some reason, the thermostat stops the flow of coolant from the bottom of the rad into the water pump until the engine is upto temp.
That said my turbo line feeds back into my top rad, so there is no flow around the turbo until my thermostat is open and coolant is flowing through the radiator.
Does anybody know if the fact my coolant line for the turbo isnt always flowing when cold will have a damaging effect? I think I will be re-routing to be safe anyway.
'Normally' coolant enters he top of a block and exits from the bottom where it has done its job and removed the heat, so your idea of reversal seems a strange one. I would also have put your gate valve before the heater matrix otherwise you'll still get residual heat from the matrix in the summer. … And does the gate valve have an alternative 'round' it when closed
