20VT Cabby problems Help Please!!!!
(In Topic #100765)
I ve had my 20vt Cabby for a year now and just recently its started to be really jerky in 3rd on boost, my fuel pump is a lot louder than usual, could it be as simple as needing a new pump, or something more sinister, Help would be gratefully accepted as Im new to this, Thanks, Paul.
really jerky??
elaberate a little please.
what pump is in there?
Cabby Problems
By really jerky I mean when i put my foot down to accelerate in third it stutters and nearly stalls then I cant rev it up, then it cuts out and wont start again for 5 to 10 mins, Then it starts up fine goes through first and second then 3 just does the same again, Its ut been MOT'ED and its annoying the hell out of me.
Member 125 - 2005
did the garage change anything to get the emissions right ? and out of interest did they class it as a mk1 or a newer mk4 ?
20vt Cabby
The garage MOT was classed as a mk1 therefore the emmissions were not a problem.
rust in the tank check the filler neck ect :wink:
3rd gear is going to be where your getting a decent constant flow of boost, ie need of fuel soooo, fuel pump, clean fuel, check plugs see if your getting over/under fueling (wideband?) spark blow out perhaps, compression test would be worth while too eliminate bore wash/ring failure. Mk1 traits, earth for the fuel pump and rust in the tank as ben says!
1982 1.8T-20v-GtEfi. K03S. Megasquirt. 16v Servo + MS. Relayed lights. Mk3 Wiper Motor… Getting too Reliable!
With thanks Eddie-Toyotec, Ben-Bens_cab, Brian-Broke and the Mk1 Owners Club! 211Bhp, should get 250 on next map!
Problems
Thanks, Ill have a look into all the above , The filler neck is rust free, Hopeully it will be one of the simple fixed problems, thanks
