2.0 8v conversion
(In Topic #158110)
Guessing the lump from the mk3 would be the best bet, not sure which engine code??
Has anyone else got the 8v conversion.
I will not be running injection as I already have a good carb on my car.
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
then you'll need an electric fuel pump, facet of some kind or some have used the post-84 mk1 cabrio/scirocco or g40 shape polo in-tank pump with success. to run it fit a kjet fuel pump relay without a rev limiter, then either run a spade with inline fuse to N on the fusebox, or get a large CE1 pin and fit it to e/14 to power the fuel pump. (don't run it off ignition live, not safe!!)
GSF sell the relay you need:
935VG0090 k-jet relay without limiter £ 23.20
I would fit a mk1/2 gti head + cam to it as well, with injector inserts blanked. if you plan to use a 2e2 carb you'll need to find a digifant or early kjet head without the vacuum tappign between ports 3 nd 4, and drill a hole for the coolant feed. if you have a weber no need to worry any gti head will do.
finally if its a tall block you may find aftermarket 4 branch hits the bulkhead, i recommend you use a std mk1/cab/rocco gti 6 bolt flange manifold and downpipe plus a gti exhaust system matched to the age of your cabrio
