2.0 16v mk3 gti engine
(In Topic #103508)
cheers in advance
PATCH WORKS UPHOLSTERY - CAMPER VAN UPHOLSTERY NEEDS
www.patchworksupholstery.net
if ur car is a small block engine then the left engine mount will need to be moved back
but if its a big block engine previously the 16v will drop in on all the mounts
93' cab in need of a miracle
rear mount can do with a little bit of spacing to help with bonnet clearance
5harp3y said
presuming from your sig that you have a gti, no mounts will have to be changed
yeah its a gti! thats great will the gearbox mount not have to be chandged i read threw a thread on the caddy forum and im sure it sed it has to be changed?
cus isnt the caddy the same as the golf upfront?
Depends what gearbox you're using……..
if its 020, then no you don't need to change them. If its 02A (which is what the ABF would have been attached to in a Mk3 GTI 16V) then yes, you need to use a custom gearbox mount. You'll also need to adapt the hydraulic clutch (can be converted to cable operation) and shift mechanism (it will be cable change). There's plenty of info around, about doing these mods.
cool cheers
