16v water pump pulley?????
(In Topic #81114)
If you measure the centre hole and bolt spacing I will check it against mine
I had problems sourcing a non power steering pulley
Mark
76 ?
78 gls
83 gti 5v
78 gls
83 gti 5v
my next step is to go to vw and buy a pulley but that requires order and therefore time so idealy i like to order the right part as they're getting a bit annoyed at me ordering parts then taking them back!! the sooner i can get this sorted the sooner she's back on the road and that time just can't come soon enough!!!
This came up when I was doing the conversion as well, G60RGE had the wrong pulley on and had overheating problems.
G60RGE fitted my old mk1 water pump pulley to sort him problem, I used one of the 9A pulleys with the second pas pulley removed. They should all be interchangeable anyway!
Did the pulley you have come with the engine? if so, likely you've got wrong pump i 'guess'.
