16v on carbs
(In Topic #111336)
16v on carbs
i no i wount need a fuel system as its not injection
so will it just be the ignition side of things i will need to wire up?
any help is help haha
mk1 golf gti in porsche ocen blue and polished porsche 7slots
then would i mate the 16v loom into the gls loom?paul_c said
Polo loom? He means polo dizzy, which has mech & vac advance. The alternative is to use the Mk2 16V ECU, which is probably the cheapest and easiest way to do it; or an aftermarket ignition ECU, which will cost a lot!
"16v loom" would be just the ignition part - which only connects to ignition components. There's only connections to the coil, earth, temp sensor, TCI and ECU. its not the "engine loom" its just a bit of wire.
The MSD setup allows for a 20* advance at 3krpms and above. it lowers the amount of retard at idle so you don't have issues trying to start it. it works great. It also has a custom pills you can buy to drop the advance at certain RPMs. At Redline you want you advance to retard a little for best performance.. but if it's a street car you should be fine without.
The units can be bought on ebay very often. or new.
MSD 6A or 6AL
MSD 8980 Timing computer
Grab your factory 6 wire ICM, 16v Distributor and you're set
Just another option for you.
79 Build thread
http://forums.vwvortex.com/zerothread?id=1713356
run the ICM directly to the coil and the distributor. you won't get any timing change, but it's easy. I actually carry that harness in my glove box just in case.
79 Build thread
mk1ash said
i did not use the polo dizzy i just used the ignition loom from the polo as its fits the dizzy , i only used it for the spark ? and it worked
Any problems starting? Have you had the car rolling road tested, or done a 1/4 mile run in it (if so, what figures did you achieve)? I reckon the lack of advance is leaving you 10-20% down on optimal performance.
