16v conversion
(In Topic #75499)
16v conversion
but what else is needed and at what cost do you guys reckon??
Mk1 1983 Helios Blue GTI Engineering
what spec is your MK1 to start with?
www.vwcaddy.com
i'm busy doing the same conversion so i'd also like to know :dontknow:
ive also heard about changing the fuel lines and driveshafts but is there anything else???
Dave's is a nice conversion and the zip file he has is very help full with wiring in the ecu etc
www.vwcaddy.com
To anybody who has done the conversion, am I right in thinking the mk2 Golf 16v driveshafts cannot be used for the conversion due to them being slightly too long?
I only ask cause I can get the mk2 Golf 16v front brake setup for ?50 including driveshafts and was just wondering whether I actually need them.
I've heard late cabby, rocco shafts are the way to go, can anyone confirm this?
Thanks 8)
An alternative to this would be to swap the drive flange on the mk2 16v gearbox to accept the smaller mk1 90mm inner cvs. This is pretty easy to do, the drive flanges are spring loaded and held in by circlips. This way you can use you existing mk1 driveshafts.
On a different not the mk2 16v brakes will not be suitable for the mk1. To go 256mm you will need to get the calipers and carriers of the early shape audi coupes/audi 80 sports. Theres a set on ebay if you are after this setup. I think it is possible to make the mk2 brakes fit but i have been told due to the hubs the car wll suffer from excessive bump steer. Someone else may be able to explain in greater detail.
Helios Blue
Thanks for the info, it all helps
appreciate it,
paul
hey Zak, hows yours going!
Helios Blue
tbh because of my slipping clutch I may as well had a 1L engine in mine for the past month or so, havent had many chances to actually give it some beans yet!
One to in the future eh! :roll:
