16v conversion
(In Topic #111627)
16v conversion
ino ill have to move one engine mount
what other mods will i need to do ?
i have a full gti 16v car to break soo i have have all the parts regarding the engine and management
is there anything els i need?
MK1 83 Jetta… 2ltr 16v ACE
MK1 88 caddy pickup 20VT soon
MK2 Golf 90spec 2ltr ABF coming soon
T5 TDI
T5 TDI
doesn't really say about gear linkage, anyone know what ill need ?
Plus you have fuelling, wheels, tyres, braking and suspension to do to. Fuelling is going to be needed, the rest is well advised, and a good opportunity to do an upgrade anyway.
i have coilovers and uprated brakes allready soo i should be okay with that
can i use the mk2 drive shafts ?
also ive heard that ill have to modify the down pipe on the exhaust manifold or buy a tubular one
kyle
i think i need a mk1 gti steering rack to mount the gear linkage on, is this the only way ?
KyleB said
ahh right kool
No, you could weld the bracket onto your existing steering rack, but you'd need the dimensions to copy exactly where to weld it to etc. Hence its a bit easier to swap the rack over.
paul_c said
KyleB said
ahh right kool
soo all i need is the rack ? no mk1 linkage needed at all
i had a look at a mk1 gti 2day and the linkage looks all different to the mk2 stuff
KyleB said
paul_c said
KyleB said
ahh right kool
You need all the linkage. Rack: swap to big block 5 speed (ie probably GTI) or weld the bracket on in the right place.
paul_c said
KyleB said
paul_c said
KyleB said
ahh right kool
okay kool cheers
sorry if im being dumb
all the mk1 linkage will bolt onto the valver box aye!
rubjonny said
etka suggests both mk2 16v shafts are the same as the scirocco 16v shafts, but from what I've read this shouldnt work? not actually tried this though.
ahh right, well i have several sets of drive shafts in the shed so im sure ill be able to sort something out :twisted:
thats kool then
thanks for the help guys
a
have a stripped shell which is goin soon, its an 86 gti cabby if u want u can come down and take the rack and al gear linkages. Will sort u a good deal out
pm me soon if interested
a
also a gti gearbox to suit or u can use the 16v box
anything else?
9a run on a variation of k-jet, just has more ecu control with a lambda sensor. with the rocco inlet you might get away with using your old intake boot, but it might not reach perfectly. Fuel lines will be fiddly as the wur & 5th injector are in a different spot, plus the injectors are round the front and not the back. as you say drop the 16v air flap and metering head on the 8v airbox, the airflap opening is bigger but you can force an 8v boot on it, just
M7R said
anything else?
Exhaust manifold
paul_c said
M7R said
anything else?
Exhaust manifold
oh I know about that, Ill use the hot tuning one as its adjustable in length…
and I ment to say injector holders not valve holders
Ill have to do the maths for bang per buck and see which wins
