16v conversion, gearbox help
(In Topic #112045)
Basically you want the full set up to match your chosen gearbox.
Flywheel:
The Mk1 and Mk2 GTI 210mm o2o flywheels are identical so either.
Pressure plate:
Either mk1 or mk2 GTI spec. They are interchangeable. 'Apparently' the 16v pressure plate has stonger springs, not totally convinced but if you have a choice…
Friction Plate:
To match the exact gearbox. These are NOT interchangeable. The Mk2 16V Golf 16V o2o friction plate has a different number of splines than the mk1 GTI o2o.
Dave
There are several 'main' parts to the o2o clutch. it (aside from bolts).
Pressure Plate (bolts to crank), then a metal disc and a metal circular clip. Then Friciton plate. Then last of all the Flywheel which bolts over the friction plate onto the pressure plate.
ETKA image for some reason doesn't show the flywheel…
Here's a pictures of the main parts, again without flywheel:
Interesting Autotech in the states offer the clutch kit for an 8V with a 16v pressure plate:
http://www.autotech.com/prod_drive_clutch.htm
certainly has no issues with my 2.0 16v abf + 020 gearbox
79 Build thread
http://forums.vwvortex.com/zerothread?id=1713356
bigcaddy said
If your pushing anything over 150hp you may want to upgrade to a performance pressure plate. Sachs has been making their pressure plates with only one strap rathen then three. Or, drill out the rivots and use straps from older pressure plates. I decided to remove my pressure plate to add straps and I'm glad I did. all the rivots were nearly out and the holes in the straps were oval shaped. so, I had an extra 16v plate and I drilled out the rivots and removed the straps. I used gauge 8 bolts on the new pressure plate to add the straps. I only double stacked mine. you can tripple them if ya want.
I have drag raced for many years and use a datalogger to analyse clutch slip. Guess what clutch I use?
Just informing the original topic poster of the weaknesses of these pressure plates.
Triple strap pressure plate shown.
79 Build thread
