16v conv drive shafts
(In Topic #115224)
which drive shafts do i need are they all the same length
cheers nick
I'm not sure if anyones established exactly which late cabbies had them fitted (?).
I have run 100mm inners on standard shafts, but it does require machining to either the shaft or CV to get the 100mm CVs on.
If you can't find any, fit 90mm Flanges to your gearbox until you do, then change em over.
