16v alternator
(In Topic #107571)
16v alternator
I need an alternator for it and i just wondered if it mattered which alternator i use whether it be one from a KR mk2 or ABF mk3.
Alternator
I hope your right because that could save me a bit of money. I have the mk1 alternator on now (loosly) minus the top bracket. But it doesnt look like the pully wheel lines up correctly. I have ordered a top bracket which should be arriving tomorow, so i shal have a go with it tomorow
Also had to use the KR adjuster bar to get the length, but ended up costing nothing and its solid as a rock. Have been running it for a fortnight now and working well, and still can change back to a mk2 item when one comes along at the right price
Let me know if you want any pictures
Ross
I have bought a kr alternator with brackets, they arived yesterday and i tried to fit it this morning. But the main KR alternator bracket doesnt fit. The bolt hole pattern is the same as that on the water pump but it doesnt fit over it.
Any help would be appreciated
What does the alternator bracket bolt onto at the bottom? because whatever it is, I havent got it.
alternator
16v altenator
So the alternator bracket is spaced away from the water pump then using nuts
Still dont know how it bolts over the lower bolts on the water pump
Shall hopefully get time to try again today.
16v altenator
I have used threaded bars and used nuts as spacers
The alternator fits fine.
However i have new problem, again. The crank pully wheel doesnt fit because the bolt pattern is different as if it has a greater pcd.
I think the pully wheel i have is from a kr engine so i think i should use one from an ABF engine. I didnt think they would be any different but they must be.
Or could i get away with drilling the holes in the pully wheel?
Ill probably have to wait another week before i can find one of them.
16v altenator
I shall have another look at it tomorow. But now im going to the pub.
