16v acc cable
(In Topic #145960)
16v acc cable
what is the best acc cable to use on a 16v conversion? carb one looks like it will fit but not sure if its the right length.
put an abf in mine and kept the carb one. fits bang on.
thanks will get one of these ordered
i use mk2 gti cables on these swaps, the carb one may be a bit long but that might work to your advantage as the mk2 gti cable has to make a pretty tight curve? i would spray a load of silicone lube down it either way even the new ones can be a bit dry
I used my original 1.3 carb throttle cable, and it fits perfectly. I didnt need to modify/bodge it at all.
