16 valve help
(In Topic #119803)
16 valve help
It started as a 1.1 so i have moved and upturned the drivers engine mount etc and the engine is in and mounted up along with the gear linkage.
I got the car with no engine and a box of bolts so its fun and games all the way ha ha
Now the issues i have are
Distributor cap fouling the brake fluid reservoir (i have a new abf one which is a screw on one but im not mega keen on bodging it on) If i use a mk2 16v setup would a standard cap fit?
Next issue is my radiator
I have the standard rad and 1 out of a 1800 16v corrado i was thinking about unpicking the filler side off the mk1 and fiiting it to the rado rad but it wouldnt work as i would lose the fan switch.
Is there a rad that has the pipe outlet on the left side along with the fan switch? Or is there a rad which goes stright in.
I have hassled dealers and g s f too much ha ha so its your turn
I have searched the site and found things useful but i didnt seem to find the info i was looking for.
HELP
Jeff
can grab them on ebay etc
I am not sure what you want with the rad, do you want the top feed on thee left and the bottom feed on the right?
std MK1/2 1.8 rad fits right in, just need to get the shroud, loom and rad pipes to go with it
dissy cap
even more oem would be audi 16v dizzy and cap, these use bolt fixing and angled upwards, but for some reason the cap is several million dollar while abf cap is pretty much exactly the same just different orientation and way cheaper
Also got a rad with a cap gonna have a mess at weekend.
Also had a mess with the carbs to see about the fueling using r1 carbs and a matching fuel pump
I think i sussed it so i can keep the standard fuel lines coming in to the engine bay and keep it looking tidy.
Will have a mess this weekend
Cheers for the replies
