16 valve conversion exhaust manifold????
(In Topic #153235)
they were very helpfull when I expressed my issues, they recommended that I modify my rear engine/gearbox mount to make it fit, however they were more than happy to let me return it which I did they even had it collected from me here in Ireland. WOW! they gave me a full refund, thats 110% for service, also there very nice people to deal with.
However my point is that if you buy a manifold surely it shoul fit without having to alter your engine mounting? I accept you will have to heat wrap it and manufacture a heatshield, however with the dubpower manifold fitted to my car the clearances were so tight there was no room to fit a heatshield.
I,m currently using a combination of 16 valve and 8 valve down pipe welded as done by rubjohnny,
any advice or experience of others much apprecieated.
The best combo I ever used was an ABF cast manifold and a TechTonics Scirocco 16v downpipe. The ABF exhaust manifold is pretty damn good for a factory cast job.
My next manifold will be custom made I think..
that said i paid a local exhaust company to help modify to fit.. and it was a nightmare as the company messed up initial alteration to the manifold..
but £200 later + a week and a half at exhaust company and it's all good now…
on a different car we are doing mk1 with tsr 16v engine that has an ashley 4 branch and that was tweeked to fit on the car, not 100% finished but clearing steering rack and drive shafts
but thats a mild steel manifolds…
hope you get this sorted
adrian
Whatever you do, protect the boot, I didn't enjoy watching my cabby burn one bit.
If you get a normal 4 branch an exhaust place could modify it, they ideally want the flange cutting off and chopping an inch off the pipes and welding up again (on mine anyway)
If you struggle with ideas for the rack boot, plenty of pics etc on my build thread. Or pm away more than happy to help.
was quoted £450ish when i first started to look into doing my conversion…
probably would have saved a few £££ by going this route, but thought it would be cheeper to go the way i did…
i was wrong…
the mild steel manifold was easily tweeked by the way..
good luck
adrian
see if i can use my mates mot station to use lift to get under, its not too pretty at moment just wanted to get it in and running..
was going to start tidying it up then after the summer..
adrian
There stainless and come with a modified gear linkage, I will update when I get a response.
So the plan is to get a 4 branch and give it a good dose of heat wrap to try and get the heat in the rear of the engine bay under control, I will probably go for an ashley as the cost is less also I have read that they are a good fit to the jetex exhaust system I have, apparently TSR recommend them, or used to.
I dont see the point of a stainless one and then wrapping it up, I think there is such a heavy flange on the stock manifold it would be very difficult to wrap properly, so hopeing to have all the bits needed by next thursday, anyone else running an ashley? how do you find it???? any advice would be most welcome cheers everyone
CRANKY said
Can you post some pictures of your Dubpower one fitted thanks
sorry for the late reply,pretty sure theres pics in my build thread from ages ago
- Project 5dr gl - 16v Kr - R1 Carbs = Back On Road
CRANKY said
Well taxed my cabrio for 3 months, 179 euro! OUCH!!! so went out for a proper spin since fitting the 16 valve engine,it,s going very well but when I got home I checked around the engine bay and the heat off the stock 16 valve manifold and my mk2 mk1 combi downpipe was unreal, the bulkhead was roasting almost too hot to touch, I had a heatshield fitted to the downpipe as per stock 8 valve downpipe, bit the heat was still unreal, no way can I drive it any distance with this going on.
I dont see the point of a stainless one and then wrapping it up, I think there is such a heavy flange on the stock manifold it would be very difficult to wrap properly, so hopeing to have all the bits needed by next thursday, anyone else running an ashley? how do you find it???? any advice would be most welcome cheers everyonecf_emoticons__BangHead:
I've seen a few customer cars on Ashley manifolds but never fitted on to a 16v conversion…though lots on 8v's…they all needed tweeking to some degree so be prepaired.
I've run a customers engine on the dyno with one making 194hp so they work well enough, tho a bit short on length.
A std cast manifold works well enough in terms of power on a std engine.
Be carefull with heat wrap…steel manifolds can crack due to the excess heat held in…normally around the flanges. I'd make a heat shield or just wrap a heat blanket around it so it can still breath top and bottom.
Put some heat proof material over the rack boot.
www.jmrclubsport.com
Sinve then I removed the Jetex exhaust system and had SOUIHAN,S in Trim Co Meath manufacture a custom stainless exhaust system using Magnaflow silencers, what a difference!! more power and way better sound! could not recommend this company enough, Souihans.ie Trim Co Meath.
In September I drove to Belfast to Titanic Dubs no problems whatsoever with either exhaust or manifold.
