16 valve conversion fuel pump not running
(In Topic #150071)
If I bridge the fuel pump relay the pump runs fine, any help apprecieated thanks
if you want to use a mk2 16v relay you will need to run the red/yellow wire from ecu to fusebox plug D/13, then fit 67, 80 or 167 pump relay.
