100mm drive flanges for 02j??
(In Topic #140954)
Well it seems I've fallen at the first hurdle with the 20vt swap. I've sourced a pair of cabby 100mm shafts and hubs but as per my usual luck my 02j box has 108mm flanges!!!
What gearbox do I need to pilfer some 100mm ones from that will work with my box? Does anyone know? Or better still does anyone have a pair there willing to sell?
Thanks in advance
Mat
Thanks in advance
Mat
So a mk3 donor is what I need then, best get round scrapyard or see what they are from steelers
Mat
Mat
Next daft qeustion is it stamped o2a stamped on the box somewhere? Just so I no were I'm looking
Mat
Mat
by the drive shaft flanges, code is on a flat surface by the starter motor
Aahh thanks, il have a search in the breakers round here
Mat
Mat
does anyone know if the gearbox from a mk2 16v gti has the correct 100mm drive flanges to swap into a 02j box? can get one in next week or so for virtually free, but need to know first before i waste my mates time lol
mat
mat
this is on ebay but im sure i see a set go for half that money
http://www.ebay.co.uk/itm/02J-100mm-GEARBOX-CUPS-RARE-1-8T-MK1-MK2-MK3-GOLF-G60-CORRADO-20VT-02A-/150766794098?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item231a66b572
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
I dont think the later later cups fitted the 020 type boxes. All depends on how they attach. Doesnt the 2y box have 100mm cups anyway?
The add reckons they bolt in so if they did would they fit? Still seems a bit steep tho!!
Mat
Mat
if your 02J has bolt in types then yes they are compatable.
you can't mix and match the circlip types with bolt types
Yeah I figured that much, still seems a bit steep tho!
Mat
Mat
Mat
yes that is a bit much,
02j boxs came with 2 differant flange sizes, 100mm 108mm.
The 100mm are from early models, 108 are from later models
MK1 Golf 4x4 Build
MK1 Golf 4X4 | Facebook
there are 2 types of 02a flange as well, bolt on and circlip fitting so make sure you get the right type. and no, 020 ones wont work at all
i used some flanges from a early mk4 tdi box, hope that helps
foxy
foxy
Ok thanks il look into it, there's a gearbox place local that reckon they've got some so il see what happevs
