1.8T 20v Manifolds
(In Topic #159916)
I am planning to use the o2A gearbox, which I can get a mount bracket for, however I want to check what manifolds I should be using.
As the AEB engine is Longitudinal, the inlet and exhaust manifolds are not suitable (from what I have read)
Can someone please confirm that it is the inlet and exhaust manifold for a MK4 golf 1.8t 20v engine that I need?
Matt
you can buy mounts that bolts to the engine and make it work for you, or as you as using the AEB you can reuse the mk1 mount.
